Non-uniform Noise Image Denoising Based on Non-local Means - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2018
Jiaxin Li
  • Fonction : Auteur
  • PersonId : 1051534
Jing Hu
  • Fonction : Auteur
  • PersonId : 1051535
Min Wei
  • Fonction : Auteur
  • PersonId : 1051536
Bin Zhang
  • Fonction : Auteur
  • PersonId : 1051537
Yanfang Wang
  • Fonction : Auteur
  • PersonId : 1051538
Restricted by camera hardware, digital images captured by digital cameras are noisy, and the noise content of each color channel of the digital image is not balanced. However, most of the existing denoising algorithms assume that the entire image noise is constant, causing errors in the denoising of color images (non-uniform noise images), affecting image noise removal and texture detail protection. To solve this problem, we propose an evaluation operator that can describe the noise content and texture content in the local area of the image. According to the description value, the image pixels are classified, and heuristic denoising parameters are selected for each class to achieve a balance between noise removal effect and texture retention effect. Experimental results of multiple denoising methods show that the proposed algorithm has better denoising effect on color images.
473854_1_En_45_Chapter.pdf (654.24 Ko) Télécharger le fichier
hal-02197770 , version 1 (30-07-2019)
Paternité
Jiaxin Li, Jing Hu, Min Wei, Bin Zhang, Yanfang Wang. Non-uniform Noise Image Denoising Based on Non-local Means. 10th International Conference on Intelligent Information Processing (IIP), Oct 2018, Nanning, China. pp.437-445, ⟨10.1007/978-3-030-00828-4_45⟩. ⟨hal-02197770⟩
38 Consultations
115 Téléchargements
