Tourist Attraction Recommendation Based on Knowledge Graph - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2018
This paper focuses on building recommendation model based on knowledge graph in the tourism field. A knowledge graph for tourist attractions in the Bangkok city is constructed, and a tourist attraction recommendation model based on the knowledge graph is presented. Firstly, we collect tourism data in Bangkok and generate a tourist attraction knowledge graph by using the Neo4j tool. Then, by applying the network representation learning method Node2Vec, we generate the feature vectors of both attractions and tourists, and calculate the correlation scores between tourists and attractions according to the cosine similarity. Finally, we normalize the correlation scores to generate the recommended list. This model presented in the paper can overcome the sparsity problem of tourist knowledge graphs and can be used in large scale knowledge graph.
473854_1_En_9_Chapter.pdf (956.65 Ko) Télécharger le fichier
hal-02197799 , version 1 (30-07-2019)
Paternité
Phatpicha Yochum, Liang Chang, Tianlong Gu, Manli Zhu, Weitao Zhang. Tourist Attraction Recommendation Based on Knowledge Graph. 10th International Conference on Intelligent Information Processing (IIP), Oct 2018, Nanning, China. pp.80-85, ⟨10.1007/978-3-030-00828-4_9⟩. ⟨hal-02197799⟩
318 Consultations
373 Téléchargements
