Periodical body's deformations are optimal strategies for locomotion - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue SIAM Journal on Control and Optimization Année : 2020
Frédéric Jean
A periodical cycle of body's deformation is a common strategy for locomotion (see for instance birds, fishes, humans). The aim of this paper is to establish that the auto-propulsion of deformable object is optimally achieved using periodic strategies of body's deformations. This property is proved for a simple model using optimal control theory framework.
Fred_Laeti_19juillet_V2.pdf (342.07 Ko) Télécharger le fichier
hal-02266220 , version 1 (13-08-2019)
Laetitia Giraldi, Frédéric Jean. Periodical body's deformations are optimal strategies for locomotion. SIAM Journal on Control and Optimization, 2020, 58 (3), pp.1700-1714. ⟨10.1137/19M1280120⟩. ⟨hal-02266220⟩
210 Consultations
247 Téléchargements
