OpenTestBed: Poor Man's IoT Testbed - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Testbeds are a key tool for evaluating and bench-marking IoT solutions. Several public testbeds are being run by institutions around the world. These are built with a variety of tools, and are typically “heavy” installations with dedicated wiring, hard installations, switches, servers, and a reservation and experiment management back-end. To complement those, we have taken the opposite, minimalistic, approach in designing the OpenTestBed. The OpenTestBed features all the tools necessary to build a testbed from off-the-shelf components such as Raspberry Pi single-board computers, OpenMote B low-power wireless devices, and glass domes. Each TestBox in the testbed connects to an MQTT broker over WiFi, no dedicated wiring or back-endis needed. The Inria-Paris OpenTestBed testbed of 80 motes has cost only 9,480 euros, and is open-access. The OpenTestBed is a fully open-source and open-hardware project, which several institutions have already adopted.
munoz19opentestbed.pdf (984.25 Ko) Télécharger le fichier
hal-02266558 , version 1 (14-08-2019)
  • HAL Id : hal-02266558 , version 1
Jonathan Munoz, Fabian Rincon, Tengfei Chang, Xavier Vilajosana, Brecht Vermeulen, et al.. OpenTestBed: Poor Man's IoT Testbed. IEEE INFOCOM - CNERT : Workshop on Computer and Networking Experimental Research using Testbeds, Apr 2019, Paris, France. ⟨hal-02266558⟩
203 Consultations
788 Téléchargements
