Molards as an indicator of permafrost degradation and landslide processes - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Earth and Planetary Science Letters Année : 2019
Molards have been defined in the past as conical mounds of debris that can form part of a landslide's deposits. We present the first conclusive evidence that molards in permafrost terrains are cones of loose debris that result from thawing of frozen blocks of ice-rich sediments mobilised by a landslide, and hence propose a rigorous definition of this landform in permafrost environments. We show that molards can be used as an indicator of permafrost degradation, and that their morphometry and spatial distribution give valuable insights into landslide dynamics in permafrost environments. We demonstrate that molards are readily recognisable not only in the field, but also in remote sensing data; surveys of historic aerial imagery allow the recognition of relict molards, which can be used as an indicator of current and past permafrost conditions. The triggering of landslides as a result of permafrost degradation will arguably occur more often as global atmospheric temperatures increase, so molards should be added to our armoury for tracking climate change, as well as helping us to understand landslide-related hazards. Finally, we have also identified candidate molards on Mars, so molards can inform about landscape evolution on Earth and other planetary bodies
Géomorphologie
HAL_Morino_etal_EPSL_2019.pdf (5.73 Mo) Télécharger le fichier
Origine : Publication financée par une institution
hal-02268386 , version 1 (20-08-2019)
Costanza Morino, Susan J. Conway, Þorsteinn Sæmundsson, Jón Kristinn Helgason, John Hillier, et al.. Molards as an indicator of permafrost degradation and landslide processes. Earth and Planetary Science Letters, 2019, 516, pp.136-147. ⟨10.1016/j.epsl.2019.03.040⟩. ⟨hal-02268386⟩
105 Consultations
96 Téléchargements
