Exploiting Symmetries When Proving Equivalence Properties for Security Protocols - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Vincent Cheval
Steve Kremer
Verification of privacy-type properties for cryptographic protocols in an active adversarial environment, modelled as a behavioural equivalence in concurrent-process calculi, exhibits a high computational complexity. While undecidable in general, for some classes of common cryptographic primitives the problem is coNEXP-complete when the number of honest participants is bounded. In this paper we develop optimisation techniques for verifying equivalences, exploiting symmetries between the two processes under study. We demonstrate that they provide a significant (several orders of magnitude) speed-up in practice, thus increasing the size of the protocols that can be analysed fully automatically.
main.pdf (815.33 Ko) Télécharger le fichier
hal-02269043 , version 1 (22-08-2019)
  • HAL Id : hal-02269043 , version 1
Vincent Cheval, Steve Kremer, Itsaka Rakotonirina. Exploiting Symmetries When Proving Equivalence Properties for Security Protocols. CCS'19 - 26th ACM Conference on Computer and Communications Security, Nov 2019, London, United Kingdom. ⟨hal-02269043⟩
84 Consultations
320 Téléchargements
