Edge focused super-resolution of thermal images - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
In this work, a super-resolution method is proposed for indoor scenes captured by low-resolution thermal cameras. The proposed method is called Edge Focused Thermal Super-resolution (EFTS) which contains an edge extraction module enforcing the neural networks to focus on the edge of images. Utilizing edge information, our model, based on residual dense blocks, can perform super-resolution for thermal images, while enhancing the visual information of the edges. Experiments on benchmark datasets showed that our EFTS method achieves better performance in comparison to the state-of-the-art techniques.
Thermal_super_resolution_IJCNN.pdf (2.57 Mo) Télécharger le fichier
hal-02270646 , version 1 (26-08-2019)
Yannick Zoetgnande, Jean-Louis Dillenseger, Javad Alirezaie. Edge focused super-resolution of thermal images. International Joint Conference on Neural Networks, Jul 2019, Budapest, Hungary. pp.1-8, ⟨10.1109/IJCNN.2019.8852320⟩. ⟨hal-02270646⟩
76 Consultations
302 Téléchargements
