Data Protection by Design for Cross-Border Electronic Identification: Does the eIDAS Interoperability Framework Need to Be Modernised? - Inria - Institut national de recherche en sciences et technologies du numérique Access content directly
Book Sections Year : 2019
Niko Tsakalakis
  • Function : Author
  • PersonId : 1052839
Sophie Stalla-Bourdillon
  • Function : Author
  • PersonId : 1052840
Kieron O’hara
  • Function : Author
  • PersonId : 1052841
This paper contributes to the discussion on privacy preservation methods in the context of electronic identification (eID) across borders through interdisciplinary research. In particular, we evaluate how the GDPR principle of ‘Data Protection by Design’ applies to the processing of personal data undertaken for identification and authentication purposes, suggesting that, in some cases, unlinkable eIDs should be a key requirement in order to facilitate data minimisation and purpose limitation. We argue that in an attempt to welcome diverse types of architectures, the Interoperability Framework could have the effect of reducing the data protection level reached by some national eID schemes, when transacting with services that do not require unique identification. We consequently propose that data minimisation and purpose limitation principles should be facilitated through the implementation of two methods, pseudonymisation and selective disclosure, through an addition to eIDAS’ technical specifications.
479119_1_En_17_Chapter.pdf (574.12 Ko) Télécharger le fichier
Dates and versions
hal-02271656 , version 1 (27-08-2019)
Attribution
Identifiers
Cite
Niko Tsakalakis, Sophie Stalla-Bourdillon, Kieron O’hara. Data Protection by Design for Cross-Border Electronic Identification: Does the eIDAS Interoperability Framework Need to Be Modernised?. Eleni Kosta; Jo Pierson; Daniel Slamanig; Simone Fischer-Hübner; Stephan Krenn. Privacy and Identity Management. Fairness, Accountability, and Transparency in the Age of Big Data : 13th IFIP WG 9.2, 9.6/11.7, 11.6/SIG 9.2.2 International Summer School, Vienna, Austria, August 20-24, 2018, Revised Selected Papers, AICT-547, Springer International Publishing, pp.255-274, 2019, IFIP Advances in Information and Communication Technology, 978-3-030-16743-1. ⟨10.1007/978-3-030-16744-8_17⟩. ⟨hal-02271656⟩
127 View
147 Download
Share
