Risk Profiling by Law Enforcement Agencies in the Big Data Era: Is There a Need for Transparency? - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Chapitre D'ouvrage Année : 2019
Sascha Van Schendel
  • Fonction : Auteur
  • PersonId : 1052855
This paper looks at the use of risk profiles by law enforcement in the age of Big Data. First, the paper discusses different use-types of risk profiling. Subsequently, the paper deals with the following three categories of challenges of risk profiling: (a) false positives (and to some extent false negatives) as well as incorrect data and erroneous analysis, (b) discrimination and stigmatization, (c) and maintaining appropriate procedural safeguards. Based on the hypothesis of risk profiling creating challenges, this paper addresses the question whether we need transparency of risk profiling by law enforcement actors, from the perspective of protecting fundamental rights of those affected by the use of risk profiles. The paper explores tackling these challenges from the angle of transparency, introducing Heald’s varieties of transparency as a theoretical model.
479119_1_En_18_Chapter.pdf (249.07 Ko) Télécharger le fichier
hal-02271665 , version 1 (27-08-2019)
Paternité
Sascha Van Schendel. Risk Profiling by Law Enforcement Agencies in the Big Data Era: Is There a Need for Transparency?. Eleni Kosta; Jo Pierson; Daniel Slamanig; Simone Fischer-Hübner; Stephan Krenn. Privacy and Identity Management. Fairness, Accountability, and Transparency in the Age of Big Data : 13th IFIP WG 9.2, 9.6/11.7, 11.6/SIG 9.2.2 International Summer School, Vienna, Austria, August 20-24, 2018, Revised Selected Papers, AICT-547, Springer International Publishing, pp.275-289, 2019, IFIP Advances in Information and Communication Technology, 978-3-030-16743-1. ⟨10.1007/978-3-030-16744-8_18⟩. ⟨hal-02271665⟩
80 Consultations
121 Téléchargements
