THB-splines: An effective mathematical technology for adaptive refinement in geometric design and isogeometric analysis - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Computer Methods in Applied Mechanics and Engineering Année : 2016
Local refinement with hierarchical B-spline structures is an active topic of research in the context of geometric modeling and isogeometric analysis. By exploiting a multilevel control structure, we show that truncated hierarchical B-spline (THB-spline) representations support interactive modeling tools, while simultaneously providing effective approximation schemes for the manipulation of complex data sets and the solution of partial differential equations via isogeometric analysis. A selection of illustrative 2D and 3D numerical examples demonstrates the potential of the hierarchical framework.
paper.pdf (4.65 Mo) Télécharger le fichier
Format : Figure, Image
hal-02271957 , version 1 (27-08-2019)
Carlotta Giannelli, Bert Jüttler, Stefan K Kleiss, Angelos Mantzaflaris, Bernd Simeon, et al.. THB-splines: An effective mathematical technology for adaptive refinement in geometric design and isogeometric analysis. Computer Methods in Applied Mechanics and Engineering, 2016, 299, pp.337-365. ⟨10.1016/j.cma.2015.11.002⟩. ⟨hal-02271957⟩
195 Consultations
331 Téléchargements
