A gravity current model with capillary trapping for oil migration in multilayer geological basins - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue SIAM Journal on Applied Mathematics Année : 2021
We propose a reduced model accounting capillary trapping to simulate oil migration in geological basins made of several rock types. Our model is derived from Darcy type models thanks to Dupuit approximation and a vertical integration in each geological layer. We propose a time-implicit finite volume scheme which is shown to be unconditionally stable and to admit discrete solutions. Numerical outcomes are then provided in order to illustrate the behavior of our reduced model.
reduced_model_revised (1).pdf (7.15 Mo) Télécharger le fichier
hal-02272965 , version 1 (28-08-2019)
hal-02272965 , version 2 (15-04-2020)
hal-02272965 , version 3 (03-01-2021)
  • HAL Id : hal-02272965 , version 2
Clément Cancès, David Maltese. A gravity current model with capillary trapping for oil migration in multilayer geological basins. SIAM Journal on Applied Mathematics, In press. ⟨hal-02272965v2⟩
194 Consultations
154 Téléchargements
