Representational Quality Challenges of Big Data: Insights from Comparative Case Studies - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2018
Agung Wahyudi
  • Fonction : Auteur
  • PersonId : 1030983
Samuli Pekkola
  • Fonction : Auteur
  • PersonId : 995664
Marijn Janssen
  • Fonction : Auteur
  • PersonId : 985668
Big data is said to provide many benefits. However, as data originates from multiple sources with different quality, big data is not easy to use. Representational quality refers to the concise and consistent representation of data to allow ease of understanding of the data and interpretability. In this paper, we investigate the challenges in creating representational quality of big data. Two case studies are investigated to understand the challenges emerging from big data. Our findings suggest that the veracity and velocity of big data makes interpretation more difficult. Our findings also suggest that decisions are made ad-hoc and decision-makers often are not able to understand the ins and outs. Sense-making is one of the main challenges in big data. Taking a naturalistic decision-making view can be used to understand the challenges of big data processing, interpretation and use in decision-making better. We recommend that big data research should focus more on easy interpretation of the data.
474698_1_En_46_Chapter.pdf (321.04 Ko) Télécharger le fichier
hal-02274148 , version 1 (29-08-2019)
Paternité
Agung Wahyudi, Samuli Pekkola, Marijn Janssen. Representational Quality Challenges of Big Data: Insights from Comparative Case Studies. 17th Conference on e-Business, e-Services and e-Society (I3E), Oct 2018, Kuwait City, Kuwait. pp.520-538, ⟨10.1007/978-3-030-02131-3_46⟩. ⟨hal-02274148⟩
116 Consultations
122 Téléchargements
