Do Business Ecosystems Differ from Other Business Networks? The Case of an Emerging Business Ecosystem for Digital Real-Estate and Facility Services - Inria - Institut national de recherche en sciences et technologies du numérique Access content directly
Conference Papers Year : 2018
Matti Mäntymäki
  • Function : Author
  • PersonId : 985690
Hannu Salmela
  • Function : Author
  • PersonId : 1053049
Marja Turunen
  • Function : Author
  • PersonId : 1053050
The concept of ecosystem emanates from ecology and subsequently has been broadly used in business studies to describe and investigate complex interrelationships between companies and other organizations. However, it is widely known that borrowing constructs from natural sciences to social sciences, or vice versa, can be problematic. For example, the use of the ecosystem concept outside its original domain has received criticism. To better understand the essence, applicability and boundaries of the business ecosystem concept, this study conducts a conceptual analysis of a set of concepts used to describe business networks. To this end, we analytically comparing business ecosystem with other prominent concepts, namely industry, population, cluster, inter-organizational network and value network. We then present an illustrative case of an emerging business ecosystem of digital services for real-estate and facility services and scrutinize the applicability of the focal concepts for our case. The results indicate a need for increased conceptual clarity when describing business networks. The results indicate a need for conceptual clarity when describing business networks. We conclude with a synthesis and discuss under what circumstances using the business ecosystem concept may add value for research and practice. The paper contributes to the business ecosystem literature by clarifying the similarities and differences between business ecosystem and other concepts used to describe business networks.
474698_1_En_11_Chapter.pdf (224.43 Ko) Télécharger le fichier
Dates and versions
hal-02274180 , version 1 (29-08-2019)
Attribution
Identifiers
Cite
Matti Mäntymäki, Hannu Salmela, Marja Turunen. Do Business Ecosystems Differ from Other Business Networks? The Case of an Emerging Business Ecosystem for Digital Real-Estate and Facility Services. 17th Conference on e-Business, e-Services and e-Society (I3E), Oct 2018, Kuwait City, Kuwait. pp.102-116, ⟨10.1007/978-3-030-02131-3_11⟩. ⟨hal-02274180⟩
41 View
690 Download
Share
