Bilinear local controllability to the trajectories of the Fokker-Planck equation with a localized control - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2019
This work is devoted to the control of the Fokker-Planck equation, posed on a smooth bounded domain of R^d (d>0). More precisely, the control is the drift force, localized on a small open subset. We prove that this system is locally controllable to regular nonzero trajectories. Moreover, under some conditions on the reference control, we explain how to reduce the number of controls around the reference control. The results are obtained thanks to a linearization method based on a standard inverse mapping procedure and the fictitious control method. The main novelties of the present article are twofold. Firstly, we propose an alternative strategy to the standard fictitious control method: the algebraic solvability is performed and used directly on the adjoint problem. Secondly, we prove a new Carleman inequality for the heat equation with a first-order term with non constant coefficients: the right-hand side is the gradient of the solution localized on a subset (rather than the solution itself), and the left-hand side can contain arbitrary high derivatives of the solution. Finally, we give an example of regular trajectory around which the Fokker-Planck equation is not controllable with a reduced number of controls, in order to highlight that our conditions are relevant.
FP.pdf (461.23 Ko) Télécharger le fichier
hal-02280501 , version 1 (06-09-2019)
hal-02280501 , version 2 (20-10-2020)
hal-02280501 , version 3 (20-11-2020)
hal-02280501 , version 4 (16-03-2021)
  • HAL Id : hal-02280501 , version 1
Michel Duprez, Pierre Lissy. Bilinear local controllability to the trajectories of the Fokker-Planck equation with a localized control. 2019. ⟨hal-02280501v1⟩
212 Consultations
192 Téléchargements
