TLA+ Model Checking Made Symbolic - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Proceedings of the ACM on Programming Languages Année : 2019
TLA + is a language for formal specification of all kinds of computer systems. System designers use this language to specify concurrent, distributed, and fault-tolerant protocols, which are traditionally presented in pseudo-code. TLA + is extremely concise yet expressive: The language primitives include Booleans, integers, functions, tuples, records, sequences, and sets thereof, which can be also nested. This is probably why the only model checker for TLA + (called TLC) relies on explicit enumeration of values and states. In this paper, we present APALACHE-a first symbolic model checker for TLA +. Like TLC, it assumes that all specification parameters are fixed and all states are finite structures. Unlike TLC, APALACHE translates the underlying transition relation into quantifier-free SMT constraints, which allows us to exploit the power of SMT solvers. Designing this translation is the central challenge that we address in this paper. Our experiments show that APALACHE outperforms TLC on examples with large state spaces.
Mots clés
camera.pdf (963.69 Ko) Télécharger le fichier
hal-02280888 , version 1 (06-09-2019)
Igor Konnov, Jure Kukovec, Thanh-Hai Tran. TLA+ Model Checking Made Symbolic. Proceedings of the ACM on Programming Languages, 2019, 3 (OOPSLA), pp.123:1--123:30. ⟨10.1145/3360549⟩. ⟨hal-02280888⟩
301 Consultations
925 Téléchargements
