Incorporating Indigenous Perspectives in Provision of E-government Services: The Case of Tanzania - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
This paper reports on the gap on perceptions of e-government for indigenous inclusion in Tanzania. E-government provisions in developing countries are linked with the use of ICT4D to support development plans. Literature indicates that development issues, cultural context and consideration of local communities’ requirements play a crucial role in facilitating adoption of e-government systems. Use of mobile phones in local communities and sharing mobile device facilities presents a unique phenomenon on utilizing e-government services in Tanzania. Drawing from in-depth interviews from government officials and citizens, the paper argue that perceived gap between central government and local communities is caused by a number of issues. The results indicate that even with few available e-government services, citizens are still keen to use them. It also emerged that there is a gap on computing facilities, central government was found to have all required minimum devices and support to access e-government services and the same was missing to the local communities. Among citizens, mobile phones were preferred way of accessing e-government services as compared to other means since they are convenient and are more personal and hence providing feeling of ownership. For the e-government services to benefits indigenous communities there is a need to address problems associated with the lack of available key e-government services in rural areas, lack of skills among government officials on public administration and development issues as well as underutilization of mobile phone for e-government services.
484106_1_En_16_Chapter.pdf (97.15 Ko) Télécharger le fichier
hal-02281291 , version 1 (09-09-2019)
Paternité
Bakari Mashaka, Neil Mcbride, Kutoma Wakunuma. Incorporating Indigenous Perspectives in Provision of E-government Services: The Case of Tanzania. 15th International Conference on Social Implications of Computers in Developing Countries (ICT4D), May 2019, Dar es Salaam, Tanzania. pp.192-202, ⟨10.1007/978-3-030-19115-3_16⟩. ⟨hal-02281291⟩
44 Consultations
61 Téléchargements
