Identifying Generative Mechanisms in a Mobile Health (mHealth) Project in Sierra Leone: A Critical Realist Framework for Retroduction - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
P. J. Wall
  • Fonction : Auteur
  • PersonId : 1023887
David Lewis
  • Fonction : Auteur
  • PersonId : 1042299
Lucy Hederman
  • Fonction : Auteur
  • PersonId : 1053554
This paper examines an ongoing mobile health (mHealth) initiative in Sierra Leone. The objective is to describe the ontological perspective and methodological approach used which relies on critical realism and Archer’s morphogenetic approach. Such a critical realist-based approach addresses many of the concerns associated with the interpretivist and positivist philosophical duopoly that has dominated the ICT4D field for many years. The approach allows the mechanisms that determined what caused the events associated with the mHealth case to be hypothesized, thus making clear why this mHealth case has sustained through many challenges.
484106_1_En_4_Chapter.pdf (265.26 Ko) Télécharger le fichier
hal-02281300 , version 1 (09-09-2019)
Paternité
P. J. Wall, David Lewis, Lucy Hederman. Identifying Generative Mechanisms in a Mobile Health (mHealth) Project in Sierra Leone: A Critical Realist Framework for Retroduction. 15th International Conference on Social Implications of Computers in Developing Countries (ICT4D), May 2019, Dar es Salaam, Tanzania. pp.39-48, ⟨10.1007/978-3-030-19115-3_4⟩. ⟨hal-02281300⟩
79 Consultations
83 Téléchargements
