Design Science Research Strengthened: Integrating Co-creation and Co-design - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Calkin Suero Montero
  • Fonction : Auteur
  • PersonId : 1054002
Alsen Florian Kapinga
  • Fonction : Auteur
  • PersonId : 1054003
Design science research (DSR) is a well-known methodology that uses design as a tool for the development of both practical research resulting in an artefact solution, and theoretical scientific knowledge resulting in improved design processes. In this paper, we advocate strengthening the DSR methodology by including elements of co-creation and co-design in order to produce meaningfully contextualised solutions and to foster a stronger sense of ownership and social acceptance of a developed technological artefact solution within ICT4D. In our work, the inclusion of co-creation and co-design within DSR takes place in all of the stages of the design cycle, influencing also the relevance and rigour cycles as well as the impact of the artefact in the broader socio-technical context. Here we illustrate the practical implementation of these ideas through the involvement of women entrepreneurs from rural Tanzania in the development of a mobile application. This paper contributes to the body of research on the meaningful application of DSR processes to ICT4D.
482525_1_En_40_Chapter.pdf (90.71 Ko) Télécharger le fichier
hal-02285314 , version 1 (12-09-2019)
Paternité
Calkin Suero Montero, Alsen Florian Kapinga. Design Science Research Strengthened: Integrating Co-creation and Co-design. 15th International Conference on Social Implications of Computers in Developing Countries (ICT4D), May 2019, Dar es Salaam, Tanzania. pp.486-495, ⟨10.1007/978-3-030-18400-1_40⟩. ⟨hal-02285314⟩
53 Consultations
151 Téléchargements
