Periodic asymptotic dynamics of the measure solutions to an equal mitosis equation - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2020
We prove, in the framework of measure solutions, that the equal mito-sis equation present persistent asymptotic oscillations. To do so we adopt a duality approach, which is also well suited for proving the well-posedness when the division rate is unbounded. The main difficulty for characterizing the asymptotic behavior is to define the projection onto the subspace of periodic (rescaled) solutions. We achieve this by using the generalized relative entropy structure of the dual problem.
measure_sol.pdf (346.55 Ko) Télécharger le fichier
hal-02290410 , version 1 (17-09-2019)
hal-02290410 , version 2 (06-11-2020)
hal-02290410 , version 3 (16-02-2022)
Pierre Gabriel, Hugo Martin. Periodic asymptotic dynamics of the measure solutions to an equal mitosis equation. 2020. ⟨hal-02290410v2⟩
238 Consultations
159 Téléchargements
