Fast and Stable Schemes for Phase Fields Models - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2019
We propose and analyse new stabilized time marching schemes for Phase Fields model such as Allen-Cahn and Cahn-Hillard equations, when discretized in space with high order finite differences compact schemes. The stabilization applies to semi-implicit schemes for which the linear part is simplified using sparse pre-conditioners. The new methods allow to significant obtain a gain of CPU time. The numerical illustrations we give concern applications on pattern dynamics and on image processing (inpainting, segmentation) in two and three dimension cases.
BrachetChehabACCH.pdf (3.88 Mo) Télécharger le fichier
hal-02301006 , version 1 (30-09-2019)
hal-02301006 , version 2 (25-03-2020)
Matthieu Brachet, Jean-Paul Chehab. Fast and Stable Schemes for Phase Fields Models. 2019. ⟨hal-02301006v1⟩
282 Consultations
390 Téléchargements
