End-to-End Learning of Semantic Grid Estimation Deep Neural Network with Occupancy Grids - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Unmanned systems Année : 2019
We propose semantic grid, a spatial 2D map of the environment around an autonomous vehicle consisting of cells which represent the semantic information of the corresponding region such as car, road, vegetation, bikes, etc. It consists of an integration of an occupancy grid, which computes the grid states with a Bayesian filter approach, and semantic segmentation information from monocular RGB images, which is obtained with a deep neural network. The network fuses the information and can be trained in an end-to-end manner. The output of the neural network is refined with a conditional random field. The proposed method is tested in various datasets (KITTI dataset, Inria-Chroma dataset and SYNTHIA) and different deep neural network architectures are compared.
unmanned_systems_2019.pdf (6.63 Mo) Télécharger le fichier
Origine : Accord explicite pour ce dépôt
hal-02302533 , version 1 (09-10-2019)
Özgür Erkent, Christian Wolf, Christian Laugier. End-to-End Learning of Semantic Grid Estimation Deep Neural Network with Occupancy Grids. Unmanned systems, 2019, 7 (3), pp.171-181. ⟨10.1142/S2301385019410036⟩. ⟨hal-02302533⟩
308 Consultations
317 Téléchargements
