Dynamical behavior of a nondiffusive scheme for the advection equation - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Confluentes Mathematici Année : 2020
We study the long time behaviour of a dynamical system strongly linked to the anti-diffusive scheme of Despr\'es and Lagoutiere for the $1$-dimensional transport equation. This scheme is nondiffusive in the sens that discontinuities are not smoothened out through time. Numerical simulations indicates that the scheme error's is uniformly bounded with time. We prove that this scheme is overcompressive when the Courant--Friedrichs--Levy number is 1/2: when the initial data is nondecreasing, the approximate solution becomes a Heaviside function. In a special case, we also understand how plateaus are formed in the solution and their stability, a distinctive feature of the Despr\'es and Lagoutiere scheme.
AntidiffusifV2-Aguillon-Guihéneuf.pdf (858.08 Ko) Télécharger le fichier
hal-02304798 , version 1 (07-10-2019)
hal-02304798 , version 2 (13-07-2020)
Nina Aguillon, Pierre-Antoine Guiheneuf. Dynamical behavior of a nondiffusive scheme for the advection equation. Confluentes Mathematici, 2020, 12 (1), pp.3-29. ⟨hal-02304798v2⟩
107 Consultations
64 Téléchargements
