Algorithms for the Sparse Random 3XOR Problem - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2020
Faster Algorithms for the Sparse Random 3XOR Problem
We present two new algorithms for a variant of the 3XOR problem with lists consisting of N n-bit 10 vectors whose coefficients are drawn randomly according to a Bernoulli distribution of parameter 11 p < 1/2. We show that in this particular context the problem can be solved much more efficiently 12 than in the general setting. In particular, we present two new algorithms. The first one has a 13 time complexity which is both O N 1+2.583p and O N 2−(1−2p) 2.1. The second one has a time 14 complexity which is almost linear in N for small values of p p ≤ 0.15 and has a time complexity of 15Õ N 2−1.97(1−2p) 2.37 for p > 0.13. The analysis of these algorithms reveal a "phase change" for a 16 certain threshold p. 17 2012 ACM Subject Classification Theory of computation → Computational complexity and cryp-18 tography; Theory of computation 19
main.pdf (635.4 Ko) Télécharger le fichier
hal-02306917 , version 1 (07-10-2019)
hal-02306917 , version 2 (12-05-2020)
hal-02306917 , version 3 (01-03-2021)
hal-02306917 , version 4 (02-10-2021)
  • HAL Id : hal-02306917 , version 2
Charles Bouillaguet, Claire Delaplace. Algorithms for the Sparse Random 3XOR Problem. 2020. ⟨hal-02306917v2⟩
267 Consultations
278 Téléchargements
