Fast Bayesian clustering and model selection for longitudinal data mixtures - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2019
Marco Corneli
  • Fonction : Auteur
  • PersonId : 1021546
Elena Erosheva
  • Fonction : Auteur
The clustering of longitudinal data from a Bayesian perspective is considered , with particular attention to the selection of the number of components. Instead of using asymptotic criteria (e.g. BIC), we propose to directly maximize an exact quantity based on conjugated prior distributions of the model parameters. The prior parameters are estimated by gradient descent, via automatic differentiation. Using simulated data, we demonstrate that, in terms of accuracy of the obtained clustering, our approach is comparable to two frequentist approaches commonly used in this setting, and it outper-forms them in selecting the actual number of clusters.
Longitudinal_mixtures__model_selection.pdf (560.05 Ko) Télécharger le fichier
hal-02310069 , version 1 (09-10-2019)
hal-02310069 , version 2 (09-10-2020)
  • HAL Id : hal-02310069 , version 1
Marco Corneli, Elena Erosheva. Fast Bayesian clustering and model selection for longitudinal data mixtures. 2019. ⟨hal-02310069v1⟩
293 Consultations
494 Téléchargements
