A hybrid high-order method for flow simulations in discrete fracture networks. - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
We are interested in solving flow in large trimensional Discrete Fracture Networks (DFN) with the hybrid high-order (HHO) method. The objectives of this paper are: (1) to demonstrate the benefit of using a high-order method for computing macroscopic quantities, like the equivalent permeability of fracture rocks; (2) to present the computational efficiency of our C++ software, NEF++, which implements the solving of flow in fractures based on the HHO method.
main-article.pdf (1.34 Mo) Télécharger le fichier
hal-02315491 , version 1 (17-12-2019)
hal-02315491 , version 2 (20-12-2019)
hal-02315491 , version 3 (21-12-2019)
hal-02315491 , version 4 (20-02-2020)
hal-02315491 , version 5 (26-05-2020)
  • HAL Id : hal-02315491 , version 3
Florent Hédin, Géraldine Pichot, Alexandre Ern. A hybrid high-order method for flow simulations in discrete fracture networks.. ENUMATH - European Numerical Mathematics and Advanced Applications Conference 2019, Sep 2019, Egmond aan Zee, Netherlands. ⟨hal-02315491v3⟩
210 Consultations
327 Téléchargements
