A Verified Accumulate Algorithmic Skeleton - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
This paper presents an extension of a library for the Coq interactive theorem prover that enables the development of correct functional parallel programs based on sequential program transformation and automatic parallelization using an algorithmic skeleton named accumulate. Such an algorithmic skeleton is a pattern of a parallel algorithm that is provided as a high-order function implemented in parallel. The use of this framework is illustrated with the bracket matching problem, including experiments on a parallel machine.
Fichier non déposé
hal-02317096 , version 1 (15-10-2019)
Frédéric Loulergue. A Verified Accumulate Algorithmic Skeleton. 2017 Fifth International Symposium on Computing and Networking (CANDAR), Nov 2017, Aomori, France. pp.420-426, ⟨10.1109/CANDAR.2017.108⟩. ⟨hal-02317096⟩
49 Consultations
0 Téléchargements
Gmail Mastodon Facebook X LinkedIn More
