The Antitumoral Effect of the S-Adenosylhomocysteine Hydrolase Inhibitor, 3-Deazaneplanocin A, is Independent of EZH2 but is Correlated with EGFR Downregulation in Chondrosarcomas
Background/Aims: 3-Deazaneplanocin, DZNep, has been reported to inhibit the EZH2 histone methylase and to induce cell apoptosis in chondrosarcomas (CS). The present study aims to confirm the therapeutic potential of EZH2 inhibitors and investigate the molecular mechanisms of DZNep in chondrosarcomas.
Methods: CS cell lines and primary cultures were used. Apoptosis was investigated using PARP cleavage, caspase 3/7 activity, or Apo2.7 expression. S-adenosylhomocysteine (SAH) and S-adenosylmethionine (SAM) were quantified by UHPLC-MS/MS. Differentially expressed genes in treated-chondrosarcomas and chondrocytes were researched by microarray analysis.
Results: DZNep induced apoptosis in chondrosarcomas both in vivo and in vitro. However, this effect was not correlated to EZH2 expression nor activity, and EZH2 knock-down by siRNA did not reduce CS viability. Additionally, the reduction of H3K27me3 induced by GSK126 or tazemetostat (EPZ-6438) did not provoke chondrosarcoma death. However, as expected, DZNep induced SAH accumulation and reduced SAM:SAH ratio. Further, microarray analysis suggests a key role of EGFR in antitumoral effect of DZNep, and pharmacological inhibition of EGFR reduced chondrosarcoma survival.
Conclusion: EZH2 is not an adequate target for chondrosarcoma treatment. However, DZNep induces apoptosis in chondrosarcomas in vitro and in vivo, by a mechanism likely mediated though EGFR expression. Consequently, it would be worth initiating clinical trials to evaluating efficiency to S-adenosylhomocysteine hydrolase or EGFR inhibitors in patients with chondrosarcomas.
2019 Aury-Landas CellPhysioBiochem DZNEP EGFR.pdf (1.41 Mo)
Télécharger le fichier
