Conference papers
Level-Shifter-Less Approach for Multi-VDD SoC Design to Employ Body Bias Control in FD-SOI
Abstract : Level shifters to convert signal swings from low-voltage (VDDL) to high-voltage (VDDH) are required at the boundary of voltage domains in SoC employing multiple supply voltages. However, they cost delay, power and area in addition to increasing the complexity of physical design. This paper proposes a level-shifter-less (LSL) approach to use a reverse body bias (RBB) at pMOS transistors in the VDDH domain and superior threshold-voltage modulation capability of FD-SOI devices. Simulation results and measurements of a fabricated chip showed that the chip applying the LSL approach correctly operates at VDDL = 0.6 V and VDDH = 1.2 V under 2 V pMOS RBB while suppressing the static dc current in the VDDH domain. We also demonstrate that adaptive RBB control for pMOS can maintain effectiveness of this approach under process and temperature variations.
Document type :
Conference papers
Complete list of metadata
Cited literature [18 references]  Display  Hide  Download
https://hal.inria.fr/hal-02319783
Contributor : Hal Ifip Connect in order to contact the contributor
Submitted on : Friday, October 18, 2019 - 11:41:54 AM
Last modification on : Friday, October 18, 2019 - 1:08:50 PM
Long-term archiving on: : Sunday, January 19, 2020 - 2:40:13 PM
File
479099_1_En_1_Chapter.pdf
Identifiers
Citation
Kimiyoshi Usami, Shunsuke Kogure, Yusuke Yoshida, Ryo Magasaki, Hideharu Amano. Level-Shifter-Less Approach for Multi-VDD SoC Design to Employ Body Bias Control in FD-SOI. 25th IFIP/IEEE International Conference on Very Large Scale Integration - System on a Chip (VLSI-SoC), Oct 2017, Abu Dhabi, United Arab Emirates. pp.1-21, ⟨10.1007/978-3-030-15663-3_1⟩. ⟨hal-02319783⟩
Share
Metrics
Record views
30
Files downloads
3
