Level-Shifter-Less Approach for Multi-VDD SoC Design to Employ Body Bias Control in FD-SOI - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Level shifters to convert signal swings from low-voltage (VDDL) to high-voltage (VDDH) are required at the boundary of voltage domains in SoC employing multiple supply voltages. However, they cost delay, power and area in addition to increasing the complexity of physical design. This paper proposes a level-shifter-less (LSL) approach to use a reverse body bias (RBB) at pMOS transistors in the VDDH domain and superior threshold-voltage modulation capability of FD-SOI devices. Simulation results and measurements of a fabricated chip showed that the chip applying the LSL approach correctly operates at VDDL = 0.6 V and VDDH = 1.2 V under 2 V pMOS RBB while suppressing the static dc current in the VDDH domain. We also demonstrate that adaptive RBB control for pMOS can maintain effectiveness of this approach under process and temperature variations.
479099_1_En_1_Chapter.pdf (747.84 Ko) Télécharger le fichier
hal-02319783 , version 1 (18-10-2019)
Paternité
Kimiyoshi Usami, Shunsuke Kogure, Yusuke Yoshida, Ryo Magasaki, Hideharu Amano. Level-Shifter-Less Approach for Multi-VDD SoC Design to Employ Body Bias Control in FD-SOI. 25th IFIP/IEEE International Conference on Very Large Scale Integration - System on a Chip (VLSI-SoC), Oct 2017, Abu Dhabi, United Arab Emirates. pp.1-21, ⟨10.1007/978-3-030-15663-3_1⟩. ⟨hal-02319783⟩
62 Consultations
88 Téléchargements
