A Recurrent Variational Autoencoder for Speech Enhancement - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
This paper presents a generative approach to speech enhancement based on a recurrent variational autoencoder (RVAE). The deep generative speech model is trained using clean speech signals only, and it is combined with a nonnegative matrix factorization noise model for speech enhancement. We propose a variational expectation-maximization algorithm where the encoder of the RVAE is fine-tuned at test time, to approximate the distribution of the latent variables given the noisy speech observations. Compared with previous approaches based on feed-forward fully-connected architectures, the proposed recurrent deep generative speech model induces a posterior temporal dynamic over the latent variables, which is shown to improve the speech enhancement results.
LAGH_2019.pdf (391.16 Ko) Télécharger le fichier
hal-02329000 , version 1 (23-10-2019)
hal-02329000 , version 2 (07-02-2020)
Simon Leglaive, Xavier Alameda-Pineda, Laurent Girin, Radu Horaud. A Recurrent Variational Autoencoder for Speech Enhancement. ICASSP 2020 - 2020 IEEE International Conference on Acoustics, Speech and Signal Processing (ICASSP), May 2020, Barcelona, Spain. ⟨hal-02329000v1⟩
456 Consultations
1240 Téléchargements
