Ontology Population Framework of MAGNETO for Instantiating Heterogeneous Forensic Data Modalities - Inria - Institut national de recherche en sciences et technologies du numérique Access content directly
Conference Papers Year : 2019
The growth in digital technologies has influenced three characteristics of information namely the volume, the modality and the frequency. As the amount of information generated by individuals increases, there is a critical need for the Law Enforcement Agencies to exploit all available resources to effectively carry out criminal investigation. Addressing the increasing challenges in handling the large amount of diversified media modalities generated at high-frequency, the paper outlines a systematic approach adopted for the processing and extraction of semantic concepts formalized to assist criminal investigations. The novelty of the proposed framework relies on the semantic processing of heterogeneous data sources including audio-visual footage, speech-to-text, text mining, suspect tracking and identification using distinctive region or pattern. Information extraction from textual data, machine-translated into English from various European languages, uses semantic role labeling. All extracted information is stored in one unifying system based on an ontology developed specifically for this task. The described technologies will be implemented in the Multimedia Analysis and correlation enGine for orgaNised crime prEvention and invesTigatiOn (MAGNETO).
483292_1_En_44_Chapter.pdf (641.65 Ko) Télécharger le fichier
Dates and versions
hal-02331295 , version 1 (24-10-2019)
Attribution
Identifiers
Cite
Ernst-Josef Behmer, Krishna Chandramouli, Victor Garrido, Dirk Mühlenberg, Dennis Müller, et al.. Ontology Population Framework of MAGNETO for Instantiating Heterogeneous Forensic Data Modalities. 15th IFIP International Conference on Artificial Intelligence Applications and Innovations (AIAI), May 2019, Hersonissos, Greece. pp.520-531, ⟨10.1007/978-3-030-19823-7_44⟩. ⟨hal-02331295⟩
110 View
28 Download
Share
