An Agent-Based Framework for Complex Networks - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
A large number of research and industrial projects could benefit from a module-based development. However, these modules and the communication between them may vary from project to project. Therefore, a general middleware instead of several specialized middlewares for each domain is desired. This paper presents the ACONA Framework (Agent-based Complex Network Architecture). It is an agent-based middleware with a lightweight and flexible infrastructure. Also, it offers the possibility of evolutionary programming. Its performance is demonstrated in three applications: (i) A cognitive architecture with around 40 interconnected modules; (ii) a stock market simulator with elements of evolutionary programming; and (iii) an industry 4.0 application of a conveyor belt.
483292_1_En_47_Chapter.pdf (879.76 Ko) Télécharger le fichier
hal-02331297 , version 1 (24-10-2019)
Paternité
Alexander Wendt, Maximilian Götzinger, Thilo Sauter. An Agent-Based Framework for Complex Networks. 15th IFIP International Conference on Artificial Intelligence Applications and Innovations (AIAI), May 2019, Hersonissos, Greece. pp.559-570, ⟨10.1007/978-3-030-19823-7_47⟩. ⟨hal-02331297⟩
41 Consultations
20 Téléchargements
