Image Recognition Based on Combined Filters with Pseudoinverse Learning Algorithm - Inria - Institut national de recherche en sciences et technologies du numérique Access content directly
Conference Papers Year : 2019
Xiaodan Deng
  • Function : Author
  • PersonId : 1056777
Xiaoxuan Sun
Ping Guo
  • Function : Author
  • PersonId : 1033430
Qian Yin
  • Function : Author
  • PersonId : 1033369
Deep convolution neural network (CNN) is one of the most popular Deep neural networks (DNN). It has won state-of-the-art performance in many computer vision tasks. The most used method to train DNN is Gradient descent-based algorithm such as Backpropagation. However, backpropagation algorithm usually has the problem of gradient vanishing or gradient explosion, and it relies on repeated iteration to get the optimal result. Moreover, with the need to learn many convolutional kernels, the traditional convolutional layer is the main computational bottleneck of deep CNNs. Consequently, the current deep CNN is inefficient on computing resource and computing time. To solve these problems, we proposed a method which combines Gabor kernel, random kernel and pseudoinverse kernel, incorporating with pseudoinverse learning (PIL) algorithm to speed up DNN training processing. With the multiple fixed convolution kernels and pseudoinverse learning algorithm, it is simple and efficient to use the proposed method. The performance of the proposed model is tested on MNIST and CIFAR-10 datasets without using GPU. Experimental results show that our model is better than existing benchmark methods in speed, at the same time it has the comparative recognition accuracy.
483292_1_En_16_Chapter.pdf (265.46 Ko) Télécharger le fichier
Dates and versions
hal-02331298 , version 1 (24-10-2019)
Attribution
Identifiers
Cite
Xiaodan Deng, Xiaoxuan Sun, Ping Guo, Qian Yin. Image Recognition Based on Combined Filters with Pseudoinverse Learning Algorithm. 15th IFIP International Conference on Artificial Intelligence Applications and Innovations (AIAI), May 2019, Hersonissos, Greece. pp.202-209, ⟨10.1007/978-3-030-19823-7_16⟩. ⟨hal-02331298⟩
54 View
40 Download
Share
