Exploring Brain Effective Connectivity in Visual Perception Using a Hierarchical Correlation Network - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Siyu Yu
  • Fonction : Auteur
  • PersonId : 1056838
Nanning Zheng
  • Fonction : Auteur
  • PersonId : 1033459
Hao Wu
  • Fonction : Auteur
  • PersonId : 1056839
Ming Du
  • Fonction : Auteur
  • PersonId : 1056840
Badong Chen
  • Fonction : Auteur
  • PersonId : 1056841
Brain-inspired computing is a research hotspot in artificial intelligence (AI). One of the key problems in this field is how to find the bridge between brain connectivity and data correlation in a connection-to-cognition model. Functional magnetic resonance imaging (fMRI) signals provide rich information about brain activities. Existing modeling approaches with fMRI focus on the strength information, but neglect structural information. In a previous work, we proposed a monolayer correlation network (CorrNet) to model the structural connectivity. In this paper, we extend the monolayer CorrNet to a hierarchical correlation network (HcorrNet) by analysing visual stimuli of natural images and fMRI signals in the entire visual cortex, that is, V1, V2 V3, V4, fusiform face area (FFA), the lateral occipital complex (LOC) and parahippocampal place area (PPA). Through the HcorrNet, the efficient connectivity of the brain can be inferred layer by layer. Then, the stimulus-sensitive activity mode of voxels can be extracted, and the forward encoding process of visual perception can be modeled. Both of them can guide the decoding process of fMRI signals, including classification and image reconstruction. In the experiments, we improved a dynamic evolving spike neuron network (SNN) as the classifier, and used Generative Adversarial Networks (GANs) to reconstruct image.
483292_1_En_18_Chapter.pdf (2.1 Mo) Télécharger le fichier
hal-02331335 , version 1 (24-10-2019)
Paternité
Siyu Yu, Nanning Zheng, Hao Wu, Ming Du, Badong Chen. Exploring Brain Effective Connectivity in Visual Perception Using a Hierarchical Correlation Network. 15th IFIP International Conference on Artificial Intelligence Applications and Innovations (AIAI), May 2019, Hersonissos, Greece. pp.223-235, ⟨10.1007/978-3-030-19823-7_18⟩. ⟨hal-02331335⟩
66 Consultations
29 Téléchargements
