Interpretable Fuzzy Rule-Based Systems for Detecting Financial Statement Fraud - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Systems for detecting financial statement frauds have attracted considerable interest in computational intelligence research. Diverse classification methods have been employed to perform automatic detection of fraudulent companies. However, previous research has aimed to develop highly accurate detection systems, while neglecting the interpretability of those systems. Here we propose a novel fuzzy rule-based detection system that integrates a feature selection component and rule extraction to achieve a highly interpretable system in terms of rule complexity and granularity. Specifically, we use a genetic feature selection to remove irrelevant attributes and then we perform a comparative analysis of state-of-the-art fuzzy rule-based systems, including FURIA and evolutionary fuzzy rule-based systems. Here, we show that using such systems leads not only to competitive accuracy but also to desirable interpretability. This finding has important implications for auditors and other users of the detection systems of financial statement fraud.
483292_1_En_36_Chapter.pdf (73.67 Ko) Télécharger le fichier
hal-02331337 , version 1 (24-10-2019)
Paternité
Petr Hajek. Interpretable Fuzzy Rule-Based Systems for Detecting Financial Statement Fraud. 15th IFIP International Conference on Artificial Intelligence Applications and Innovations (AIAI), May 2019, Hersonissos, Greece. pp.425-436, ⟨10.1007/978-3-030-19823-7_36⟩. ⟨hal-02331337⟩
65 Consultations
64 Téléchargements
