Completeness of an Axiomatization of Graph Isomorphism via Graph Rewriting in Coq - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2019
The labeled multigraphs of treewidth at most two can be described using a simple term language over which isomor-phism of the denoted graphs can be finitely axiomatized. We formally verify soundness and completeness of such an axiomatization using Coq and the mathematical components library. The completeness proof is based on a normalizing and confluent rewrite system on term-labeled graphs. While for most of the development a dependently typed representation of graphs based on finite types of vertices and edges is most convenient, we switch to a graph representation employing a fixed type of vertices shared among all graphs for establishing confluence of the rewrite system. The completeness result is then obtained by transferring confluence from the fixed-type setting to the dependently typed setting.
coq-2pdom.pdf (638.23 Ko) Télécharger le fichier
hal-02333553 , version 1 (25-10-2019)
hal-02333553 , version 2 (26-10-2019)
hal-02333553 , version 3 (08-01-2020)
  • HAL Id : hal-02333553 , version 2
Christian Doczkal, Damien Pous. Completeness of an Axiomatization of Graph Isomorphism via Graph Rewriting in Coq. 2019. ⟨hal-02333553v2⟩
456 Consultations
457 Téléchargements
