Optimal cavity shape design for acoustic liners using Helmholtz equation with visco-thermal losses - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Tissot-Gabard_AIAA_2019.pdf (611.18 Ko) Télécharger le fichier
hal-02335834 , version 1 (28-10-2019)
Gilles Tissot, Gwenael Gabard. Optimal cavity shape design for acoustic liners using Helmholtz equation with visco-thermal losses. Aeroacoustics 2019 - 25th AIAA/CEAS Aeroacoustics Conference, May 2019, Delft, Netherlands. pp.1-11, ⟨10.2514/6.2019-2471⟩. ⟨hal-02335834⟩
86 Consultations
189 Téléchargements
