Fixed-Order Scheduling on Parallel Machines - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
We consider the following natural scheduling problem: Given a sequence of jobs with weights and processing times, one needs to assign each job to one of m identical machines in order to minimize the sum of weighted completion times. The twist is that for machine the jobs assigned to it must obey the order of the input sequence, as is the case in multi-server queuing systems. We establish a constant factor approximation algorithm for this (strongly NP-hard) problem. Our approach is necessarily very different from what has been used for similar scheduling problems without the fixed-order assumption. We also give a QPTAS for the special case of unit processing times.
ZBScheduling_.pdf (317.27 Ko) Télécharger le fichier
hal-02336592 , version 1 (29-10-2019)
Thomas Bosman, Dario Frascaria, Neil Olver, Rene Sitters, Leen Stougie. Fixed-Order Scheduling on Parallel Machines. Integer Programming and Combinatorial Optimization (IPCO), 2019, Ann Arbor, United States. pp.88-100, ⟨10.1007/978-3-030-17953-3_7⟩. ⟨hal-02336592⟩
80 Consultations
197 Téléchargements
