The implicit discretization of the super-twisting sliding-mode control algorithm - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue IEEE Transactions on Automatic Control Année : 2020
This paper deals with the analysis of the time-discretization of the super-twisting algorithm, with an implicit Euler method. It is shown that the discretized system is well-posed. The existence of a Lyapunov function with convex level sets is proved for the continuoustime closed-loop system. Then the global asymptotic Lyapunov stability of the unperturbed discrete-time closedloop system is proved. The convergence to the origin in a finite number of steps is proved also in the unperturbed case. Numerical simulations demonstrate the superiority of the implicit method with respect to an explicit discretization with significant chattering reduction.
BBSTA.pdf (536.41 Ko) Télécharger le fichier
hal-02336599 , version 1 (29-10-2019)
Bernard Brogliato, Andrey Polyakov, Denis Efimov. The implicit discretization of the super-twisting sliding-mode control algorithm. IEEE Transactions on Automatic Control, 2020, 65 (8), pp.3707-3713. ⟨10.1109/TAC.2019.2953091⟩. ⟨hal-02336599⟩
157 Consultations
879 Téléchargements
