Stability and convergence analysis of artificial boundary conditions for the Schrödinger equation on a rectangular domain - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Mathematics of Computation Année : 2021
Based on the discrete artificial boundary condition introduced in [16] for the two-dimensional free Schrödinger equation in a computational rectangular domain, we propose to analyze the stability and convergence rate of the resulting full scheme. We prove that the global scheme is L 2-stable and that the accuracy is second-order in time, confirming then the numerical results reported in [16].
MathOfComp-PangYangAntoineTang.pdf (347.48 Ko) Télécharger le fichier
hal-02340837 , version 1 (31-10-2019)
hal-02340837 , version 2 (12-06-2021)
  • HAL Id : hal-02340837 , version 1
Gang Pang, Yibo Yang, Xavier Antoine, Shaoqiang Tang. Stability and convergence analysis of artificial boundary conditions for the Schrödinger equation on a rectangular domain. Mathematics of Computation, 2021. ⟨hal-02340837v1⟩
Collections
IECLEDP
188 Consultations
203 Téléchargements
