Finite-time guaranteed state estimation for discrete-time systems with disturbances - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
In this paper, we consider a family of discrete-time systems with input and output. A new technique, based on past values of the output which have been employed to construct some finite-time observers for continuous-time systems in the literature, is proposed for discrete-time case. The systems are affected by additive disturbances and disturbances in the output. Exact estimation or approximate estimation can be achieved depending on the absence or the presence of unknown but bounded uncertainties, respectively.
Automatique
tdetal_acc19_v1.pdf (324.51 Ko) Télécharger le fichier
hal-02342708 , version 1 (01-11-2019)
Thach Ngoc Dinh, Frédéric Mazenc, Tarek Raïssi. Finite-time guaranteed state estimation for discrete-time systems with disturbances. SysTol 2019 - 4th International Conference on Control and Fault-Tolerant Systems, Sep 2019, Casablanca, Morocco. pp.342-347, ⟨10.1109/SYSTOL.2019.8864742⟩. ⟨hal-02342708⟩
83 Consultations
267 Téléchargements
