Output Global Oscillatory Synchronization of Heterogeneous Systems - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue International Journal of Control Année : 2019
Hafiz Ahmed
Yongqiang Wang
The global output synchronization problem for heterogeneous nonlinear systems having relative degree 2 or higher is studied. The proposed approach consists in two steps. First, a partial projection of individual subsystems into the Brockett oscillators is performed using a sliding-mode control. Second, the network of these oscillators is synchronized using the global synchronization results of a particular second order nonlinear oscillator model from Ahmed et al. (2019). Our approach is based on output feedback and uses a higher order sliding mode observer to estimate the states and perturbations of the synchronized nonlinear systems. Along with numerical simulations, the performance of the proposed synchronization scheme is experimentally verified on a network of Van der Pol oscillators.
_Final_Manuscript_TCON_2018_0553.pdf (1.3 Mo) Télécharger le fichier
hal-02344850 , version 1 (04-11-2019)
Hafiz Ahmed, Rosane Ushirobira, Denis Efimov, Leonid Fridman, Yongqiang Wang. Output Global Oscillatory Synchronization of Heterogeneous Systems. International Journal of Control, 2019, ⟨10.1080/00207179.2019.1690689⟩. ⟨hal-02344850⟩
61 Consultations
191 Téléchargements
