Autostereoscopic transparent display using a wedge light guide and a holographic optical element: implementation and results - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Applied optics Année : 2019
We present a novel transparent autostereoscopic display consisting of laser picoprojectors, a wedge light guide, and a holographic optical element. The holographic optical element is optically recorded, and we present the recording setup, our prototype, as well as the results. Such a display can superimpose 3D data on the real world without any wearable.
AutostereoTransparent.pdf (2.57 Mo) Télécharger le fichier
hal-02352672 , version 1 (06-11-2019)
Thomas Crespel, Patrick Reuter, Adrian Travis, Yves Gentet, Xavier Granier. Autostereoscopic transparent display using a wedge light guide and a holographic optical element: implementation and results. Applied optics, 2019, 58 (34), ⟨10.1364/AO.58.00G293⟩. ⟨hal-02352672⟩
334 Consultations
377 Téléchargements
