Blockchain as a Trusted Component in Cloud SLA Verification - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Migrating an application from local compute resources to commercial cloud compute resources involves giving up full control of the physical infrastructure, as the cloud service provider (CSP) is responsible for managing the physical infrastructure, including its security. The reliance of a tenant on a service provider can create a trust issue around whether the CSP is upholding its end of the bargain. CSPs acknowledge this and provide a guarantee through a Service Level Agreement (SLA). SLAs need to be verified for satisfaction of the defined objectives. Such a verification procedure needs to be unbiased and independently achievable i.e. both tenants and CSPs should be allowed to run the verification without relying on the other party, otherwise the trust issue can be raised again. In this paper, we consider an SLA offered by the provider that guarantees the integrity of tenants' data, and propose a verification method, i.e. an integrity checking method, which is based on a distributed ledger. Specifically, our proposed method allows both CSPs and tenants to perform integrity checking without one party relying on the other. The method uses a blockchain, a distributed ledger, to store evidence of data integrity. Assuming the ledger as a secure, trusted source of information, the evidence can be used to resolve conflicts between providers and tenants. In addition, we present a prototype implementation and an experimental evaluation to show the feasibility of our verification method and to measure the time overhead.
sample-sigconf.pdf (1 Mo) Télécharger le fichier
hal-02354647 , version 1 (07-11-2019)
hal-02354647 , version 2 (08-11-2019)
hal-02354647 , version 3 (13-11-2019)
Amir Teshome Wonjiga, Sean Peisert, Louis Rilling, Christine Morin. Blockchain as a Trusted Component in Cloud SLA Verification. International Workshop on Cloud, IoT and Fog Security, Dec 2019, Auckland, New Zealand. ⟨10.1145/3368235.3368872⟩. ⟨hal-02354647v1⟩
171 Consultations
533 Téléchargements
