Filterbank design for end-to-end speech separation - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Single-channel speech separation has recently made great progress thanks to learned filterbanks as used in ConvTasNet. In parallel, parameterized filterbanks have been proposed for speaker recognition where only center frequencies and bandwidths are learned. In this work, we extend real-valued learned and parameterized filterbanks into complex-valued analytic filterbanks and define a set of corresponding representations and masking strategies. We evaluate these fil-terbanks on a newly released noisy speech separation dataset (WHAM). The results show that the proposed analytic learned filterbank consistently outperforms the real-valued filterbank of ConvTasNet. Also, we validate the use of parameterized filterbanks and show that complex-valued representations and masks are beneficial in all conditions. Finally, we show that the STFT achieves its best performance for 2 ms windows.
main.pdf (301.31 Ko) Télécharger le fichier
hal-02355623 , version 1 (08-11-2019)
hal-02355623 , version 2 (10-02-2020)
  • HAL Id : hal-02355623 , version 2
Manuel Pariente, Samuele Cornell, Antoine Deleforge, Emmanuel Vincent. Filterbank design for end-to-end speech separation. ICASSP 2020 - 45th International Conference on Acoustics, Speech, and Signal Processing, May 2020, Barcelona, Spain. ⟨hal-02355623v2⟩
307 Consultations
573 Téléchargements
