ABE for DFA from k-Lin
We present the first attribute-based encryption (ABE) scheme for deterministic finite automaton (DFA) based on static assumptions in bilinear groups; this resolves an open problem posed by Waters (CRYPTO 2012). Our main construction achieves selective security against unbounded collusions under the standard k-linear assumption in prime-order bilinear groups, whereas previous constructions all rely on q-type assumptions.
