Language Processing for Predicting Suicidal Tendencies: A Case Study in Greek Poetry - Inria - Institut national de recherche en sciences et technologies du numérique Access content directly
Conference Papers Year : 2019
Alexandros Dimitrios Zervopoulos
  • Function : Author
  • PersonId : 1058242
Evangelos Geramanis
  • Function : Author
  • PersonId : 1058243
Alexandros Toulakis
  • Function : Author
  • PersonId : 1058244
Asterios Papamichail
  • Function : Author
  • PersonId : 1058245
Dimitrios Triantafylloy
  • Function : Author
  • PersonId : 1058246
Theofanis Tasoulas
  • Function : Author
  • PersonId : 1058247
Katia Kermanidis
  • Function : Author
  • PersonId : 992337
Natural language processing has previously been used with fairly high success to predict a writer’s likelihood of committing suicide, using a wide variety of text types, including suicide notes, micro-blog posts, lyrics and even poems. In this study, we extend work done in previous research to a language that has not been tackled before in this setting, namely Greek. A set of language-dependent (but easily portable across languages) and language-independent linguistic features is proposed to represent the poems of 13 Greek poets of the 20th century. Prediction experiments resulted in an overall classification rate of 84.5% with the C4.5 algorithm, after having tested multiple machine-learning algorithms. These results differ significantly from previous research, as some features investigated did not play as significant a role as was expected. This kind of task presents multiple difficulties, especially for a language where no previous research has been conducted. Therefore, a significant part of the annotation process was performed manually, which likely explains the somewhat higher classification rates compared to previous efforts.
Keywords
484534_1_En_15_Chapter.pdf (193.61 Ko) Télécharger le fichier
Dates and versions
hal-02363833 , version 1 (14-11-2019)
Attribution
Identifiers
Cite
Alexandros Dimitrios Zervopoulos, Evangelos Geramanis, Alexandros Toulakis, Asterios Papamichail, Dimitrios Triantafylloy, et al.. Language Processing for Predicting Suicidal Tendencies: A Case Study in Greek Poetry. 15th IFIP International Conference on Artificial Intelligence Applications and Innovations (AIAI), May 2019, Hersonissos, Greece. pp.173-183, ⟨10.1007/978-3-030-19909-8_15⟩. ⟨hal-02363833⟩
87 View
74 Download
Share
