Strong differential observability for sampled systems - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2019
In this paper we prove that, generically, a sampled data system is strongly differentially observable provided that the number of outputs is greater than the number of inputs plus one.
strong-diff-obs.pdf (463.2 Ko) Télécharger le fichier
hal-02377400 , version 1 (23-11-2019)
hal-02377400 , version 2 (01-02-2021)
  • HAL Id : hal-02377400 , version 1
Sabeur Ammar, Jean-Claude Vivalda, Basma Zitouni. Strong differential observability for sampled systems. 2019. ⟨hal-02377400v1⟩
81 Consultations
186 Téléchargements
