Monotone and second order consistent schemes for the Pucci and Monge-Ampere equations - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2019
We introduce a new strategy for the design of second-order accurate discretiza-tions of non-linear second order operators of Bellman type, which preserves degenerate ellipticity. The approach relies on Selling's formula, a tool from lattice geometry, and is applied to the Pucci and Monge-Ampere equations, discretized on a two dimensional cartesian grid. In the case of the Monge-Ampere equation, our work is related to both the stable formulation [FJ17] and the second order accurate scheme [BCM16]. Numerical experiments illustrate the robustness and the accuracy of the method.
PucciMA_Hal.pdf (1.86 Mo) Télécharger le fichier
hal-02383521 , version 1 (27-11-2019)
hal-02383521 , version 2 (31-05-2020)
  • HAL Id : hal-02383521 , version 1
Joseph Frédéric Bonnans, Guillaume Bonnet, Jean-Marie Mirebeau. Monotone and second order consistent schemes for the Pucci and Monge-Ampere equations. 2019. ⟨hal-02383521v1⟩
284 Consultations
179 Téléchargements
