Exploiting structure of uncertainty for efficient matroid semi-bandits - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Michal Valko
We improve the efficiency of algorithms for stochastic combinatorial semi-bandits. In most interesting problems, state-of-the-art algorithms take advantage of structural properties of rewards, such as independence. However, while being optimal in terms of asymptotic regret, these algorithms are inefficient. In our paper, we first reduce their implementation to a specific submod-ular maximization. Then, in case of matroid constraints , we design adapted approximation routines , thereby providing the first efficient algorithms that rely on reward structure to improve regret bound. In particular, we improve the state-of-the-art efficient gap-free regret bound by a factor √ m/ log m, where m is the maximum action size. Finally, we show how our improvement translates to more general budgeted combinato-rial semi-bandits.
supplementary.pdf (882.58 Ko) Télécharger le fichier
hal-02387478 , version 1 (29-11-2019)
  • HAL Id : hal-02387478 , version 1
Pierre Perrault, Vianney Perchet, Michal Valko. Exploiting structure of uncertainty for efficient matroid semi-bandits. International Conference on Machine Learning, 2019, Long Beach, United States. ⟨hal-02387478⟩
138 Consultations
117 Téléchargements
